hello,
is there a possibility to mix the volumes of master and headphone in the headphone? so i could here the master on my headphone while pitchin the next track
thank you,
greez, Tom
thank you,
greez, Tom
geposted Tue 20 Dec 05 @ 10:29 am
use a skin like mix station 04.
-gauge
-gauge
geposted Tue 20 Dec 05 @ 10:41 am
and then, is it possible to make a keyboard shortcut for this function?
geposted Tue 20 Dec 05 @ 2:11 pm
In fact you could use a PFL Headphones effect too. Not sure if you could get the short cut in this.
geposted Tue 20 Dec 05 @ 11:27 pm
yes it is possible to make a shortcut...
goto the mixtable and select headphone mix..or wherever you find it..
the CDJ 700 is also a good skin which has this feature
cheers
DJ Rudra
cheers
DJ Rudra
geposted Wed 21 Dec 05 @ 4:34 pm
No it´s not. Because Headphone Mix does not let you hear the MASTER(!!!) in the headphones, but only both decks. Meaning - you don´t hear your fade in/out moves. So while HeadphoneMix does help a lot, it´s still not the same. I have asked for this feature several times, in the forums and directly via eSupport. No answer in any way. Traktor btw has this feature.
geposted Wed 28 Dec 05 @ 4:50 pm
