i changed my old HDJC for the new MK2...how can i register? i'm registered with old one
geposted Fri 23 Dec 05 @ 4:59 am
go into "modify my profile"then where it says you can put your serial number in for software use the serial number for your hercules mk2. i havent actually done this but i am pretty sure that is where you enter your serialnumber
-gauge
-gauge
geposted Fri 23 Dec 05 @ 6:19 am
thats exactly it :) enter serial for the mk2 console in your profile :)
http://www.virtualdj.com/fusers/modifuser.html
geposted Fri 23 Dec 05 @ 3:22 pm
Hey guys, i tried with serial code below the HDJC shown at a stiker but i have an invelid code message? where is serial number?
geposted Sat 24 Dec 05 @ 3:56 am
can it be serial from vdj 3.0 that cmes with the console? i'm using 3.2 that i bought few months ago....
geposted Sat 24 Dec 05 @ 3:57 am
Yes, that's it, the serial number of the VDJ that comes with the console. You can enter it to be recognized as a mk2 user, even if you're using the full-version you purchased (don't worry, it will not "downgrade" you, you'll still have the Professional Edition status, plus the mk2 icon)
geposted Sat 24 Dec 05 @ 7:59 am
@djkike
The serialnumber is NOT the on the sticker on the console :)
Its on the cover of the CD that came with the Console (the white cover that the cd was in)
geposted Sat 24 Dec 05 @ 1:32 pm
Hello,
the white cover came with no serial number
geposted Sat 24 Dec 05 @ 4:56 pm
seems like there was a batch of MK2 consoles being distributed without that serial code on the CD envelope, you can see it in hercules webpage, and how to get yours. Too bad yours was one of those.
Is it mk2 good? I'm planning to finally leave 1.09 (and forget about my crapy "unpushable" DJC MK1), but I'm taking my time, maybe in the meantime Behringer BCD2000 is released.
Good luck with your issue.
Alejandro.
Alejandro.
geposted Sun 25 Dec 05 @ 1:47 am
MK2 looks good and cue/play buttons are real time. The problem is that my 3.2 version crashes continuosly since i changeg mk1 for mk2. I hope is just drivers update, mk2 is better for working
geposted Sun 25 Dec 05 @ 3:04 am
Hey,
have you got the site where i can get serial. i cannot find it at hercules website
geposted Sun 25 Dec 05 @ 3:08 am
My fault, I even got it in my clipboard when I wrote my first comment but I forgot to paste it (getting old? maybe :P)
the address is http://us.hercules.com/products/showfaq.php?p=110&b=0&show=&f=1
merry christmas to all of you
geposted Mon 26 Dec 05 @ 10:00 pm
I've already got it.
Thanks a lot for your support
Merry Christmas
Merry Christmas
geposted Mon 26 Dec 05 @ 10:12 pm
and update your Hercules drivers + firmware also
They have released a fix for Virtual DJ 3.2 at the Hercules site
geposted Tue 27 Dec 05 @ 9:00 pm
I already updated firmware and drivers the very first day. There is also a thing to do with the old ASIO driver form old console, it must be deleted manually from windows registry. I'll tell you if error continues.
Now i have also intalled VDJ's version that comes with mk2, so i have my registered copy that i bought diretly from VDJ and the limited version from hercules, i'll try which one gives me less problems...
geposted Wed 28 Dec 05 @ 4:06 am
Does anyone knows when i must set MK2 control panel audio settings to WDM or to ASIO?
geposted Wed 28 Dec 05 @ 12:05 pm
In my 3.2 dj console version I can use only the WDM mode, the ASIO doesn't work.
I have the driver and firmware update with the latest version.
geposted Wed 28 Dec 05 @ 1:49 pm
kike> VDJ takes care of it. By default it forces the use of WDM mode. If you select "use TCV", then it'll switch the console to ASIO itself.
geposted Wed 28 Dec 05 @ 2:05 pm
What is TVC?
Which is the diference between ASIO and WDM?
geposted Wed 28 Dec 05 @ 2:39 pm
TCV = time coded vinyl (for controlling Virtual DJ using real turntables)
ASIO = a soundcard driver mode, that ensure low-latency when using timecode vinyl
WDM = the regular soundcard mode with Windows drivers (good for regular use, not for timecode use)
geposted Wed 28 Dec 05 @ 2:57 pm
