I got a question for everyone,
i have been playing around with this software for about two days now and i woul dlike to know if you use the timecode vinl/cd for would you go about in switchin the video aspect of it. for example when you move you crossfader to the right you here turn table one, then to the right you hear turntable number two , but when you have video inplemented how would you go about in fade from one to the other ?.
the other question is and it's probably a dumb question but when hooked up via time encoded do you have to keep your fader in the center software wise.
geposted Wed 28 Dec 05 @ 7:47 pm
when mixing video using timecode /external mixer... you need to crossfade the video manually (either in skin using video crossfader, or by keyboard shortcuts)
Or you can do it by external midi controller (for example Hercules), or get an external mixer where the real hardware crossfader can be mapped to also crossfade video (midi hybrid mode).
Such as the Nou4 mixer, and some others coming up very shortly
geposted Thu 29 Dec 05 @ 4:55 pm
