will the MP3 quality effect the sound quality of scratching?? when loadin from CD what qulity is it? .wav or .MP3 ? :o)
geposted Fri 06 Jan 06 @ 8:53 pm
1) yes the quality of the mp3 is very important for playing with VDJ (so to scratch too) as VDJ uncompress the mp3 file into the memory so even if VDJ works in 44100Hz and 16 bits, the higher kbps you have the better uncompressed quality file you have
=> i advise you 192kbps minimum for scratch
2) if it's a audio CD it will be in wav.
if it's a mp3 cd, it will be a mp3 then converts into wav inside the memory
geposted Fri 06 Jan 06 @ 9:28 pm
