I asked myself if there's an effect like the standard brake of VDJ but with higher adjustability of more than 4 seconds.. i mean like 10 seconds .. sry for bad english i am german ^^
J0Ke
J0Ke
geposted Fri 13 Jan 06 @ 1:44 pm
nobody knows?
geposted Fri 13 Jan 06 @ 3:10 pm
Another user made especially for me a version of the brake fx sometime, but these happens only if you are registered user....
geposted Fri 13 Jan 06 @ 3:20 pm
Some of the effects makers could change the current brake pluggin to have a 10 sec brake. Anyway, You don't be able to have it because only registered users are capable to download effects, samples and pluggins.
It could be done, but you need to be a register user, to be a full registered user buy VDJ.
geposted Fri 13 Jan 06 @ 9:10 pm
i dont understand why i am not registered.. i bought the hercules mk II and vdj comes together with it and i registered it with the code which i found in the box..
geposted Sat 14 Jan 06 @ 9:03 pm
Than go to your profile and detect the console which will give you the appropriate status on the site, making some effects available for download.
geposted Sat 14 Jan 06 @ 10:05 pm
erxon meant to write your serial in your profile to detect your version of VirtualDJ
geposted Sun 15 Jan 06 @ 2:06 am
