On my pc the skin JN-SILVER VDJ v1.03 doesn't work well,
The buttons like the play button don't work... With al 4 skins.
Is that my pc? or doesnt the skin work well?
thanx
thanx
geposted Fri 20 Jan 06 @ 2:54 pm
why are you using such an old skin??? if your using a newer version of VDJ then that skin might not work. If you bought the program please update your profile.
geposted Fri 20 Jan 06 @ 3:14 pm
i don't know if I should post it here or not,
btw i have a problem with the default skin I'm using with virtual dj.
The Cursor doesn't appear as a cursor but just as a BLACK SQUARE.
Can anybodu help me with this or can you address me to another topics so that somebody can help me.
Thank you, Keep mixrockin'.....
geposted Tue 24 Jan 06 @ 2:32 pm
what kind of VDJ version are you working with??if you're working with a cracked version is normal you have a lot of problems.please enter your registration code in your profile and update or buy your legal copy of the software...
geposted Mon 30 Jan 06 @ 10:48 am
