directX sound driver error, what does it means?
geposted Tue 24 Jan 06 @ 10:12 am
I have Win XP SP2 with the latest dirextx, Virtual dj 3.3 and all is ok.
Get the latest version: http://www.microsoft.com/windows/directx/downloads/
geposted Tue 24 Jan 06 @ 12:39 pm
This error means VDJ doesn't recognize (find) a sound output (maybe used in the past: external sound card in general)
Go to the sound settings in VDJ and select the config again
geposted Tue 24 Jan 06 @ 12:44 pm
I juse external soundcard but stil the problem is there. i never had trouble with it.Only since yersterday.Do i Have to download the new directx
geposted Tue 24 Jan 06 @ 1:36 pm
Start-> Run
type in 'dxdiag'
you should see version 9.0c (or later if there is a later one?)
If not, see one of the posts above to download the latest version.
type in 'dxdiag'
geposted Tue 24 Jan 06 @ 5:06 pm
DirectX sound driver error also happens if you switch your sound board in ASIO mode, while running VirtualDJ in DirectX mode, so that VirtualDJ doesn't detect the direct Sound card.
Check if it also happens when you switch your sound card in WDM mode instead of ASIO prior to running VirtualDJ.
geposted Thu 26 Jan 06 @ 11:33 am
