I've put a similar question to Creative support and the forums but have received no responses, so I was hoping someone here might have an idea :)
I have an X-Fi Platinum which comes with a Drive Bay. On the drive bay is a headphone jack that seems to play back the audio from all the channels no matter what speaker setup I choose (i.e. if I choose heaphone, 5.1 or 7.1, all 2, 6 or 8 channels are sent through the heaphone jack).
Does anyone know if there's a way to specify which channel(s) go to that jack?
geposted Thu 02 Feb 06 @ 7:32 pm
Well on all creative sound card if it isn't wrong, when you plug the headphone on heaphone, all is sent on headphone output as you said
So you have to connect your headphone on rear output and not on headphone output
geposted Thu 02 Feb 06 @ 7:37 pm
I managed to get it working on the rear juck with VDJ's "7.1" setting and the "Advanced Config" (ASIO) setting, but I was hoping that there was a way that I could only send specific channels to the front jack =/
Does anyone know for sure if this is/isn't possible?
geposted Thu 02 Feb 06 @ 7:43 pm
Thanks for the input, acw. I received a reponse from Creative this morning that confirms what you said. Looks like I'm going to have to use the setup that you specify in your blog :)
geposted Fri 03 Feb 06 @ 6:38 pm
