i am running virtual dj pro version with tccd and denon dn-d6000 cd players. i hooked up one side of the player to my factory installed soundcard and got 100% timecode quality (just wanted to test it out). the problem is computer and cd players dont seem to be syncing right. when i adjust the pitch on the denons, its doesnt keep up with the pitch on the VDJ. Also when i try to do a seemless loop it loops correctly the first two times, but then loses its place. is this because of the quality of my soundcard??? reason im asking is i dont want to spend the money on a soundcard if the setup isnt going to work correctly. computer has atholon 3000+ and 512mb ram
geposted Thu 16 Feb 06 @ 1:48 am
clore46,
You can't reproduce in a standard soundcard what we really got with ASIO soundcards like ESI-U46DJ or others. VirtualDJ works very good. I suggest you upgrade to 1GB your laptop RAM and by a ESI- U46DJ to work with VDJ and TCCDs.
geposted Sun 19 Feb 06 @ 6:24 am
