While using TCV's, one deck will stop working. I can load a song but it will not play. I have to shut down VDJ and open the program again in order for both decks to work.
This has happened to me while I was broadcasting on VDJ radio.
What is the fix for this problem?
geposted Tue 21 Feb 06 @ 5:12 am
Have you tried to go into your Virtual DJ settings under the timecode and try to do an auto-detect to fix the TCV not working?
geposted Tue 21 Feb 06 @ 3:18 pm
that happens to me when i select both inverse audio options IN TC config. i do not need to select them but i get no clicks or pops when it is like that, but i agree. also try select a different soundcard setting and then select ASIO TC again, it seems just need a refreshing, but give more details about your setting. Also you try lowering your buffer in the ASIO options?
geposted Tue 21 Feb 06 @ 3:49 pm
All my settings seem fine.
I can load a song, tcv can see it and control it, but NO SOUND comes through.
It's like a pre crash or something.
geposted Tue 21 Feb 06 @ 9:44 pm
so you lose sound but not control ?? you can still see the waving be controlled, you have a maya 44 correct? is the driver up to date?
geposted Tue 21 Feb 06 @ 10:19 pm
That is correct. I lose sound but can still control the wave w/ tcv.
Yes...I have the Maya44USB and all drivers are up to date.
geposted Wed 22 Feb 06 @ 6:47 pm
I have to say VDJ (for me) seems to have alot of random bugs in it. I have had many different things that happen once and dont happen again. sometimes my timcode signal will be 0 when both decks are playing but ether one on its own will be fine
just weird things like that. i dont mind cause a quick re-execute seems to sort it but it is a bit disconcerting.
geposted Thu 23 Feb 06 @ 1:08 am
