I use the automix option, "Force fade" option is enabled. I have put cue points in the mp3's I mix. Fadelength is 1 sec. Crossfader is set on "Scratch".
Fore some files, it is better to cut them and switch directly to the other song.
I do not seem to get this working in Virtual DJ 3.2. When use the BPM button to adjust BPM values en choose the "edit automix" pane, i can choose the cut option, but this seems not to work, the cut cue point seems not to be set.
Most of the songs I want to be cross faded, only some to be cut.
How can i get this working ? Am I doing something wrong ?
thx
thx
geposted Sun 26 Feb 06 @ 7:17 pm
Johny Turbo,
What you are doing wrong is using an unauthorized version. You have and ilegal version. Download the trial version here (Demo version) or purchase a legal copy in this site.
geposted Sun 26 Feb 06 @ 10:06 pm
Will these options work correctly then ?
I do not spent 134 euro's if i'm not sure its working right.
geposted Tue 28 Feb 06 @ 8:15 pm
The CUT mix option does not work in the trial version. I set in via the BPM menu, edit automix. The point is cleared after closing this menu item.
This is normal in the trial version ?
geposted Tue 28 Feb 06 @ 8:28 pm
