Is there any way of locking the interface to the monitor you want it to appear on,
I have a multiple monitor setup and play the Video on the primary monitor, this is because the Hardware acceleration for MPEG2 files performs way better on the primary monitor, the
hassle is when you start up Virtual DJ you have to drag it across every time.
geposted Thu 02 Mar 06 @ 6:47 am
if you have multiple monitors then go to control pannel / display / settings and u will see mon 1, 2, 3 etc based on how many you have. click on 'identify' and it will tell you which monoror is which. click on the square box #1:There are 2 check boxes 1 for 'primary monitor' and 1 for 'extended'. do same for al lmonitors.
the monitor you wish to nominate as primary click on this box for that monitor - the other monitors will automatically then uncheck this box. click on 'extended for the other monitors (s) ie the one (s) for full video.
if you have more than 2 monitors let me know
davefromlondon
davefromlondon
geposted Thu 02 Mar 06 @ 8:14 pm
