Hi,
(I don't use vinyl)
I will use Asio with my Waveterminal 192 X :
it doesn't work !
"error in driver asio"
In mixvibes6 , Waveterminal 192 X asio last drivers work perfectly.
Asio works with indigo Dj with virtual dj, but the level is very very very low (please check the level in asio)
With WDM/KS drivers same problem with echo dj and waveterminal 192 X :
the sound level is very low. (even if i set to the maximum the drivers settings for each soundcard)
(In directsound the level is ok)
So, please take a look to the mixvibes6 demo or djdecks and compare .
In mixvibes or djdecks ASIO and WDM/KS level are ok. not in virtualDJ.
i will not work with directsound (MME) drivers.
Olivier
(I don't use vinyl)
it doesn't work !
Olivier
geposted Thu 02 Mar 06 @ 3:45 pm
HI,
With the update Virtual DJ 3.4 :
Asio sound level is OK with ECHO INDIGO DJ. (and last echo drivers)
but...
Impossible to choose 96khz/24 bits in ASIO
I will check my other soundcard : waveterminal 192X tomorrow
but...
geposted Thu 02 Mar 06 @ 8:59 pm
