I am having a problem with skipping when I use Windows media player to load a song while a song is playing.
Example:The playlist has 10 songs, I load a song from my DVD/CD drive and when the loads into the right side, I get clipping/skipping.
I tried another way and tried copying the song from the CD "on the fly" with windows media player and when it starts to burn the song I get the same clipping in my virtual DJ.
I have a laptop with a 1.6 Gb processor and 512 Mb RAM.
Are their any adjustments I can make to stop this?
This is a concern because if I get a request of a song I don't have, I can load it up in my computer and play away.
geposted Thu 09 Mar 06 @ 3:43 pm
What ver do you have and is it registered? Did you know you can load and play a cd using VDJ?
geposted Thu 09 Mar 06 @ 7:34 pm
It is my friends and it is registered, but I think it is 3.2
I tried the virtual DJ loading of the CD and it still clips.
geposted Thu 09 Mar 06 @ 8:07 pm
So the registered user, let you have a copy? Why not do what he did, to get it to work on his machine? Also 3.4 is available to registered users.
geposted Thu 09 Mar 06 @ 9:08 pm
what??
I have his laptop? he needed help with it.
Are you saying if he gets 3.4 that will fix the problem?
geposted Thu 09 Mar 06 @ 10:15 pm
In config try increasing the sound-card latency [turn off auto and set to 128ms] and check box the safe mode option.
geposted Wed 20 Apr 11 @ 12:54 pm
wow ! you posted in a 6 years old ancient topic regarding ancient ver 3.4.
Please download the latest Free Home version 7 https://virtualdj.com/download/free.html and open a new thread describing your issues.
Topic locked
geposted Wed 20 Apr 11 @ 2:08 pm
