I did the trial version of vdj and loved it, i also ordered the tcv's and when they come in I am gonna get the full version of vdj, my question goes something like this, could i get some help with the configuration process when i become a registered user of the program, i have a x-fi platinum sound card so would i need to purchase anthing more?
geposted Sat 25 Mar 06 @ 4:53 am
Tris sound card is from Creative, right? It is not so cheap sound card ;)
Well.. looks that it has 2 RCA jacks for AUX in. So you can connect your turntables to them and it should work.
After buying VDJ check how VDJ see this sound card in andvanced config menu and then write back if you won't know how to configure it.
geposted Sat 25 Mar 06 @ 10:44 pm
I just bought a hercules dj console mk2 since maya is still back ordered @ musicians friends....
the console isnt hilighted in my profile ... How do i register it so it will show up ? there are some numbers on it but i dont know if its a serial number or what.
PLZ help me
PLZ help me
geposted Wed 05 Apr 06 @ 5:11 am
geposted Wed 05 Apr 06 @ 6:49 pm
