hello I have been reading all the posts, and find them very helpfull, I have downloaded the trial to my home pc and had no problems (after reading pcgumshoe's awesome notes) I have absolutely fell in love with the program...... When i installed it on my laptop and following the same procedures, I can't seem to get graphics. XP home sp2 2.4ghz downloaded and installed the following net framework, aspi drivers, directx 9, ligos indeo video 5.1. All devices report they are working properly. I have not installed any of the ripping tools to my laptop, as i will be ripping them with my home pc to an external hard drive to take on the road. I think I covered everything that I did and have installed!! Any more suggestions will be helpful.
Thanks Bunches!
Craig
Thanks Bunches!
Craig
geposted Tue 04 Apr 06 @ 7:42 am
Take a look at this, and see if it will help you. https://virtualdj.com/forums/48397/General_Discussion/Virtual_DJ_doesn_t_turn_on____only_splash___icon_in_taskbar__fixed_.html
geposted Tue 04 Apr 06 @ 7:57 am
nope didn't work....thanks for the reply!
geposted Tue 04 Apr 06 @ 8:05 am
So you have a demo on 2 machines? Did you copy the demo from one machine to the other, or download each one separately? Have you tried to re-install?
geposted Tue 04 Apr 06 @ 8:17 am
yes i actually downloaded to the laptop first, not having any luck on the laptop i then tried my luck with the home pc
geposted Tue 04 Apr 06 @ 8:27 am
