I am trying to get the headphones work on one of the four stereo outputs of my Terratec 7.1 Space PCI soundcard, so I can cue up tracks, while the master volume comes out of my speakers. Does anyone have any suggestions? Terratec haven't replied about this yet.
Many thanks,
.ioannis.
Many thanks,
.ioannis.
geposted Thu 13 Apr 06 @ 2:12 pm
First of all you have to have full version of VDJ. Next, in advanced config of audio cards you can set whatever you want :) Your sound card will work great like you wish!
geposted Thu 13 Apr 06 @ 2:33 pm
So I guess the most important thing is that the headphones won't work at all in the trial version, right?
Many thanks xeon.
Many thanks xeon.
geposted Thu 13 Apr 06 @ 4:01 pm
Just got a reply from Terratec that the particular card does not support the multi-MME standard and it thus won't work with VIRTUAL DJ.
geposted Thu 13 Apr 06 @ 6:46 pm
I didn't see sound card that won't do with VDJ yet. I think it will.
geposted Thu 13 Apr 06 @ 7:23 pm
bonjour
g acheté une carte son externe g fai la configuration et tout mai kan je vien pour mixer je peu pa mixer avec le caske plu de 15 min pk? aider moi stp o plu vite
geposted Wed 03 Oct 12 @ 5:29 pm
bossluid wrote :
bonjour
A moins que ta la version home de vdj seulement 10 minutes des fonctions pro seront disponibles pour ce temps faudrait acheter la version pro.
P.S Conseil, prochaine fois poser vos question dans le forum français vous etes sur le forum anglais.
https://virtualdj.com/forums/29/French_Forum.html
geposted Wed 03 Oct 12 @ 11:47 pm
