Forum: Old versions
Topic: My pitch slider in VirtualDJ...
BMANHome userMember since 2004
is used for adjusting the volume of the track, and vice versa the volume knob adjusts the pitch.. Why is this?
Can't I correct this?
I want the pitch on the console to adjust the pitch in virtualDJ, and the volume knob to adjust the volume..How do I go about this? Is it even possible?
Thank u kindly..
geposted Tue 01 Jun 04 @ 10:49 am
If i wasn't clear enough in my previous post..In short:
My pitch slider on the hercules DJ console sets the volume in Virtual DJ, and my volume knob adjusts the tempo/speed. It's all the other way around..
geposted Tue 01 Jun 04 @ 10:52 am
Go in VDJ's options, and in the "Remote Control" panel, there is a checkbox that says "Invert Pitch/Volume". This will invert them so they match what is written on the console.
Cheers, macourteau
geposted Tue 01 Jun 04 @ 11:38 am
BalunanHome userMember since 2004
Åh!
I wanted to know that too! :D
Thanks guys!
geposted Tue 01 Jun 04 @ 12:47 pm
