HI *,
has anyone experience with a Maya7.1 Soundcard?
Or is there a List of supported Soundcards?
Are there changes between Atomixmp3 and VDJ in respect to soundcard configuration or dirvers.
Thx in advance
Thx in advance
geposted Thu 03 Jul 03 @ 2:55 pm
Hi,
well i have the Maya 5.1 and it works very good. No problems.
Janosch
Janosch
geposted Fri 04 Jul 03 @ 4:26 am
Janosch,
you have the Maya 5.1, and you use it with Atomix right ?
Are you able to use 2x2 outputs and to mix on an external mixer???
According that Atomix does not support ASIO and that USB does not enable MME and/or Direct X to deal with 2 individual outputs on the USB port, how do you do this ????
Thanks
Thanks
geposted Fri 04 Jul 03 @ 9:43 pm
i haven't got this card, you have tried to have atomix in 3d-card mode? with no success?
geposted Fri 04 Jul 03 @ 10:01 pm
I have the same card you got go in sound confg and set it 4.1 and you will get two out puts on for player A and the other for player B
geposted Wed 15 Oct 03 @ 2:50 am
