When I use 24bit ASIO I get a massive load of static noise instead of music. I am taking the Output 1+2 feed from the console to the linein on my other pc which does any recording/broadcasting - and also has speakers attached.
I thought it was fully ASIO compliant. Am using VDJ 3.4, and latest firmware.
Any pointers?
Any pointers?
geposted Thu 27 Apr 06 @ 9:26 pm
use 16bit ;)
geposted Thu 27 Apr 06 @ 9:57 pm
That sounds a bit "squelchy"... :( Like its over sampled, when the input coming in on soundcard linein is less than -6dB. Same level sounds tons better on WDM.
geposted Thu 27 Apr 06 @ 10:17 pm
Maybe you need to increase your buffer size.
geposted Thu 27 Apr 06 @ 10:33 pm
It's still not sounding right. Just listened to a recording I did on console mk1 and its a million miles better sound quality. Something is not set right :(
geposted Sat 29 Apr 06 @ 2:35 pm
I use 16-bit and the highest buffer sixe... :) works fine...
geposted Sat 29 Apr 06 @ 3:21 pm
@SiDHEaD : What settings do you have for the mk2 asio ?
geposted Sat 29 Apr 06 @ 4:13 pm
16bit and all different buffers...
Have had a thought - it might be somehow due to remote desktopping to the DJ box (waiting for a TFT to arrive for it), even though the sound is coming straight out of the back of the mixer not through remote desktop.
I'll wait till I am sure it isn't that and bump this.
Thanks
Thanks
geposted Sun 30 Apr 06 @ 2:40 pm
Tried it properly, not through RDP, and it was still crap sounding. :(
geposted Mon 01 May 06 @ 7:44 pm
