Does anyone know the specifics on how I can make VDJ map the different inputs of the X-Fi I/O console as TCCD inputs, and spit them to specific output ports on the X-Fi? It has been mentioned that there are some registry settings called ASIOMapChanIn and ASIOMapChanOut, but I can't find anything to really explain how to use them.
It has been mentioned I can use ASIO4All, but I would rather not use some sort of emulation software when I have a fulyl capable 24-bit sound card in there. I have also used the U46DJ successfully, but again...why can't this sound card be good enough? It has enough ASIO channels.
I want to map the Aux 2 input port to the FL/FR output line, and the Aux3 input port to the RL/RR output line.
Thanks,
Andrew
Thanks,
Andrew
geposted Mon 01 May 06 @ 8:30 pm
i have the same pb with this guy i dou not know how connect vdj+mixer+creative x-fi+denon s5000 for using tccd
geposted Tue 07 Nov 06 @ 11:30 pm
