Forum: Old versions
Topic: Help !
I'm a new user and have the hercules mk2 console. All is great and am getting on well with except............ when I cue in my next track it goes in fine, but when the other track stops, I get a second or two where vdj freezes, (did that make sense? :S) Anyone else have this problem and how is it solved?
Cheers, Bex..x
geposted Fri 12 May 06 @ 11:01 am
try defragmenting your harddrive that should speed it up
aslo removing unwanted programs and files should speed up your computer
what are your computer specs?
Windows xp with service pack 2
pentium 4 cpu 1700 MHz
1.69 GHz
640 mb ram
40 gig hardrive (has operating system on, programs, etc)
60 gig hardrive (stores my music)
It doesn't need defraging (done last week)
It's just a second that it stops for when after cueing in my next track and the last one ends.
sounds like you should try
www.theorica.net/gamexp.htm
it looks at the serivces that are running and stops them if they are not needed
this can help remove odd laggs in your computer
The main features of the program are:
Game XP has been designed to speed up your computer by optimizing system settings in the most efficient way to allow for maximum gaming experience.
Makes games to run faster and boosts overall performance of your computer.
Optimizes your 3D card performance for maximum gaming experience and much more...
No installation or modification needs to be made to your hardware.
If system analysis of Game XP match your computer then simply press the "Go to Warp Speed" button.
It does not need any DLL or another file(s). It is just a single "EXE" file: GameXP.exe
Easy to use interface.
No installation necessary.
No experience or computer skills necessary!
you can aslo use
http://www.theorica.net/safexp.htm
to impove the proformance of your computer
It allows you to take control of your PC.
Make Windows to run faster and more secure.
Protect your privacy and strength Internet protection.
Disable Spyware-like activities of Windows XP (also 2000&ME&98) Operating System, Media Player, Internet Explorer and Outlook.
Disable unnecessary Windows services like System updates, error reporting and much more...
Prevent Internet attacks, any RPC/DCOM related vulnerabilities and fix exploits like DSO.
Disable script-based attacks on Windows Media Player, Internet Explorer and Outlook.
Block Windows Messenger (spam) vulnerabilities.
Restrict the actions of potentially dangerous "HTA" (Hypertext Application) capabilities in any version of Windows.
It does not need any DLL or another file(s). It is just a single "EXE" file: SafeXP.exe
How EVER i must Stress the importance of always making a back up before using this type of program
you can do this in the main window
Both programs are free
hope this info helps
aslo if you use the default windows defrager it tends to make things worse
try using one of these free ones
http://www.softpedia.com/get/System/OS-Enhancements/FAST-Defrag-FREEWARE.shtml
Cheers mate, will give that a go ;) :)
any joy?
