Forum: Old versions
Topic: mp3s taken ages to load
Hi had this problem a while ago and it seemed fine after the updates
but again it has returned
when draging an MP3 on to a deck to play it takes for ever to fully load the track
i have defraged and done all the other things like virtual memory ect
i am running 1gig memory
2000 cpu
80 gig hard drive
geposted Wed 17 May 06 @ 4:19 pm
do the songs look like they have been already anaylized? did you try the speedload tweak?
Hi yes al songs have been pre analysed
what is the speedload twaek please?
thanks
Hi thanks did that but it was already at 0
thanks for your help
oops yes your right default is 0 so change it to a 1 ... i forgot i did my home comp already too
what it change actually?
thx
changing it from 0 to 1 makes the mp3's load faster but leaves less room for error for video files this isnt a problem if your video's all run fine
As it comes with the time, i think you have to defragmentate your hard disc
I did Defrag!if you read my original post!
yep changed it to 1 seams much better thanks for your help
no problem rossy glad to help
