Having problems with karaoke files not playing. Some files Load and play music but don't play the graphic. More recently ripped karaoke cds wont load at all and the player displays "error". None of them crash Virtual DJ but they just don't load and these same files all work in PCDJ which is what I switch from. Any solutions would be great. Thanks
System Info:
AMD Athlon 3400+
1 Gig DDR
WinXP Professional SP2
Running Virtual DJ Ver. 3.4
NVIdia AGP Dual View
RIpping CD+G using Power CD+G Burning Software
System Info:
AMD Athlon 3400+
1 Gig DDR
geposted Thu 22 Jun 06 @ 5:27 am
Ripping problems, Try to convert them into another type of file if you are able to do so. I dont use Karaoke so I cant really tell you what software to use or what format is better, but Im sure you can find it for yourself.
Hope this could help.
Karlo.
Karlo.
geposted Thu 22 Jun 06 @ 12:15 pm
It has to do with what you zipped them with. I unzipped all my files and rezipped them with MP3+G Toolz 4 and all work perfect now
geposted Thu 22 Jun 06 @ 5:11 pm
it does have to do with the zip i usually move them to the desktop and using winrar right click extract here and then stick the 2 files back in the archive. works fine afterwards
geposted Thu 22 Jun 06 @ 5:55 pm
Check my post on "Solution to Zip Errors..."
geposted Fri 03 Nov 06 @ 7:31 am
