hey everyone i just ordered my second pair of tcv and i noticed that as soon as i started scratching with them, the needle would jump all over the place and they don't seem to be as pressed as my old one i'm just wondering if i have to break them in to get a good scratch or what because my old one give great scratchnig sound but teh new iones are just not cutting in
let me know somone
squeeze eye
let me know somone
squeeze eye
geposted Sat 22 Jul 06 @ 6:33 pm
increase your needle pressure, apply antiskate pressure as needed, mine also skiped quite easily for a while.
also recalibrate your tonearms to make sure you havnt messed them up acidentaly
geposted Sat 22 Jul 06 @ 11:26 pm
Also how new are your needles?
geposted Sun 23 Jul 06 @ 12:00 am
ABOUT 6 MONTHS OLD
geposted Sun 23 Jul 06 @ 3:59 am
Are the holes in the records to big? If you can jiggle them slightly, it is. Try attaching a small piece of masking tape or similar through the hole to keep the record from sideways movement.
It does sound strange that they are "jumping all over"... May simply be bad prints. As for breaking them in, to my knowledge records are never better then when they are brand spanking new.
Anyway, how are the new TCV's? Are they louder? Are the grooves deeper og shallower?
geposted Sun 23 Jul 06 @ 5:03 am
Try a newer stylus..maybe yours is worn down
geposted Sun 23 Jul 06 @ 6:49 pm
THE GROOVES ARE SHALLOWER
geposted Sun 23 Jul 06 @ 7:13 pm
that sucks, are you sure its that? im sure VDJ would be more careful chosing new TCV, if its good enough for Numark its good enough for me. are the VDJ v2 TCVs the same as the Numark ones? if not just get a pair of Virtual Vinyl ones
geposted Sun 23 Jul 06 @ 7:45 pm
A quarter might be a little overboard I remember using nickles ...but i guess it goes up with Gas Prices
geposted Mon 24 Jul 06 @ 6:53 am
Yeah I recently brought new timecoded vinyls.. but they are badly bent from shipping id guess.. Is there any way id be able to replace them or... because it cost me a hundred and something aussie dollars to get them over here due to shipping costs and what not and id say they just arent acceptable :-(
geposted Mon 24 Jul 06 @ 11:01 am
for all problems concerning tcv please
contact
contact
geposted Mon 24 Jul 06 @ 2:20 pm
whats up man,
i used to dj with the hercules rmx but now i wanna get into turntables and so i need some help setting up my equipment.
i just wanted to know how do you set up the turntable weights and the antiskates.
i mostly beat mix hip hop music but would like to start scratching into my mixes, not extensively though,
this is what i use for my equipment:
virtual dj pro 5.2.1
numark ttx tts
numark cc1 cartridges
numark ppd01 for a mixer
hercules rmx for a soundcard
ssl2 tcvs
ANY ADVICE AND SUGGESTIONS ARE WELCOME AND HIGHLY APPRECIATED! THANKS so much!
numark ttx tts
ssl2 tcvs
geposted Mon 09 Mar 09 @ 9:41 am
