Hi,Im trying to figue out how to mix about 10 tracks together for a dance performance im putting together..here's an example
http://www.youtube.com/watch?v=aRNzWyD7C9o
i want to make a mix lyk dat but wit different songs...can n-e one help me?
geposted Mon 24 Jul 06 @ 6:46 am
Well.. you don't have to have much mixing skills to make such a mix. There are no transitions. You will have to listen all songs and make a mark when there is great part in each song and then cut it out with music software. Then you can simply put these parts together in music software again, or you can mix them using VDJ but it will be difficult because you will have only few seconds to select song, and mix it. The best way will be to put them in playlist (make it before) and enable automix in VDJ. I think that way you can make great mix for such a dance. Just listen to songs and find the best part of each ;)
Hope that helps... I made a lot of such mixes for dance. I am making them for one dance school near me. And i use VDJ for put them together :)
geposted Mon 24 Jul 06 @ 10:27 am
Thanx alot...I'll try that out
geposted Mon 24 Jul 06 @ 5:38 pm
