sup guys i'm new at this and i was wondering how i can mix or dj live on here can someone help me with that plz?
geposted Mon 31 Jul 06 @ 9:11 pm
you have to be a registered full member to play on VDj Radio
geposted Mon 31 Jul 06 @ 9:17 pm
yes, you must buy the software from here:
https://virtualdj.com/purchase/
geposted Mon 31 Jul 06 @ 9:25 pm
well thanks i seen my ip is says i can hve freinds listening 2 me live some how no clue how tho
geposted Mon 31 Jul 06 @ 9:56 pm
you're welcome, hope to see you as a full member soon, regards.
geposted Mon 31 Jul 06 @ 9:59 pm
can u tell me why it says my ip and it says if i give my freinds it they can here me but for some reason when i type in that ip it gives me a file and i hit save and it just sends files thats it can't here?
geposted Mon 31 Jul 06 @ 10:19 pm
i mean for now can freinds here me it keeps telling me they can but how?
geposted Mon 31 Jul 06 @ 10:21 pm
you can use the demo to broadcast , but your question was how to broadcast live on here
geposted Mon 31 Jul 06 @ 10:29 pm
demo what do u mean i have tryed but i don't know how 2 use demo and it doesn't say nothing about how 2 use a demo if u don't mind can u tell me how 2 use it and where 2 get it from?
geposted Wed 02 Aug 06 @ 10:52 pm
To mix on VirtualDJ Radio, so here: http://radio.virtualdj.com/listen/
you will need FULL PRO version of VirtualDJ. You can buy it here: https://virtualdj.com/purchase
you said that you had 2 friends listening to you. So you are using demo (trial) version of VIrtualDJ. And you already set your home radio station if there are listeners.
To listen what you are broadcasting you have to save file and then open it in winamp or windows media player or another software. Or you can type provided address (with your ip inside) directly to player (usualy at File -> Play / Open URL). And you can listen your mix!
geposted Wed 02 Aug 06 @ 10:59 pm
well honestly there wasn't nobody listening 2 me there was a link with a ip thing that i gave them and when i did and they typed it in and they hit enter a file come up 2 save something and it just stayed like that i don't have a radio station set up because i dont no how 2 set it up
geposted Thu 03 Aug 06 @ 5:16 pm
