hi ..
just a quick question .. with the VDJ software is it only possible to rceord live mixing or is there an option to keep working on your mix .. and keep saving or updating the saved file ..so that once you get that perfect mix you can burn it onto a cd or mp3 ??
How do you go abt doing that if its possible ?
thnks for yr help
thnks for yr help
geposted Fri 04 Aug 06 @ 2:12 pm
Not possible. VDk is ment for live performance.
geposted Fri 04 Aug 06 @ 3:52 pm
u can record live, also if u messed up and want to edit just play the mix while u re-record it and blend out before the mess-up part comes in , kinda hard though to blend with the demo version as theres no headphone ability
geposted Fri 04 Aug 06 @ 7:15 pm
Sounds like what you're after is some kind of sequencing program, something like Acid or Protools maybe...
geposted Fri 04 Aug 06 @ 7:59 pm
yes, if you want to edit music you need some other software as mentioned above, since vdj is only for live performance.
Manquin DJ
Manquin DJ
geposted Fri 04 Aug 06 @ 8:14 pm
Thanks for your replies & suggestions guys ..
geposted Sat 05 Aug 06 @ 7:13 am
you're welcome DjNikhil, hope to see you mixing soon as a registered user, best regards.
geposted Sat 05 Aug 06 @ 2:04 pm
