is it possible to control the crossfader on vdj with your mixer(i'm using a newmark 200fx mixer).if so how can this be done?and what can i use to control it.
geposted Thu 10 Aug 06 @ 10:59 am
It's not possible to control the crossfader directly (not even with midi mapping, it's not fully implemented) yet, but it's a far better solution to route 2 seperate audio outputs in the mixer and from there to speakers. That is the basic function of a mixer ;)
Choose one of these options, depending on which soundcard(s) you have:
Hope that answers your question,
best regards.
Ps.: It's Numark, not Newmark ;)
- if you have only one stereo output, use the Y-splitter mode in which case you'll be mixing two mono signals.
- with 4.1 soundcard you can use stereo front and stereo back outputs to route 2 stereo signals into the mixer. With 5.1, center output can be used for samples in mono.
- with two 5.1 soundcards more options are possible.
- use the advanced config to apply each setting independantly
best regards.
geposted Thu 10 Aug 06 @ 11:17 am
