Hi, I was thinking of purchasing the ConsoleDJ thing lol ;]
But anyway, If i was to purchase that [ From Argos! lol ] Is it the Newest Edition Of VirtualDJ which has the 'Put your hands up in the air' FX's already installed.
And if it isn't and i would like to purchase VirtualDJ[Newest Edition], how would i use the actual Console From Hercules ConsoleDJ with VirtualDJ if i Purchased the actual VirtualDJ Edition?! ;]
Thanks
Sean
Thanks
Sean
geposted Fri 18 Aug 06 @ 1:18 am
go here to see what you get with the different versions
https://virtualdj.com/products/comparison.html
the upgrade is definately worth it, you get console mapper, effects, skins, samples, DJ on the radio, all sorts of things
geposted Fri 18 Aug 06 @ 1:28 am
Thanks Xeo,
Do you know if i will get the 'Put your hands up in the air' tune ? lol ;]
geposted Fri 18 Aug 06 @ 1:41 am
you do with the version i have, the full one, i think you would probably get it with the console version too
geposted Fri 18 Aug 06 @ 2:16 am
Ok,
Thanks for the help mate..
Sean
Sean
geposted Fri 18 Aug 06 @ 2:19 am
Seaneh wrote :
Thanks Xeo,
The track that you are looking for is UBP feat Bobby Pruit - We Are One, and it's the Hands-Up-A-Pella that you want, which can be found here...
http://www.traxsource.com/index.php?act=show&step_id=82d2b5ff0e94c53e68490349fd59f78f&fc=tpage&cn=title_id&cv=566
geposted Fri 18 Aug 06 @ 4:10 am
