Forum: Old versions
Topic: VDJ 4.0 and TCVs
how do i congifure VDJ 4.0 to work w/ my TCVs???
geposted Fri 25 Aug 06 @ 10:06 pm
nevermind i figured it out..
How did you do it?
can you make a guide ?
Seems many cant figure this out, and it would be really helpfull ;)
yeah sure no problem... here it is step by step (SETUP FOR TCVs on VDJ 4.0)
1. Open VDJ, Go click on CONFIG (upper right hand corner)
2. Click the SOUND SETUP tab.
3. Click the down arrow on INPUTS.
4. Select TIMECODES the one w/ two turntables and the laptop.
5. Next click on the down arrow for OUTPUTS.
6. Select EXTERNAL MIXER.
7. Next click the down arrow for SOUNDCARD(S).
8. Select Maya44 USB. or AISO if using a different soundcard than the Maya44.
9. Try to use your timecoded vinyls now and see if that works for you.
-Other than that, if you're still experiencing problems, I would follow VDJ's website instructions on setting up your TCVs and Turntables to your computer.
