i heard somewhere that u could connect a camera to vdj to show live feed of the club on the screen ...how is that done ? all i see is a feature to scratch with a web cam .also i don't see karaoke button either.
can some one point this out for me ...thankx in advance
geposted Mon 28 Aug 06 @ 5:42 am
Look in VDJ video effects ;)
You will see CAMERA there ... ;)
geposted Mon 28 Aug 06 @ 12:23 pm
Yes, it's not a SETUP/CONFIG option
Is just a VIDEO PLUGIN/EFFECT
geposted Mon 28 Aug 06 @ 1:17 pm
As for the Karaoke button, maybe you are thinking of some inferior DJ software ;) in which a karaoke file is treated differently than any other media file and requires a special player or a special button to indicate that it is a karaoke file.
In VDJ, it is much simpler. If an MP3 has a matching CDG file, then it is treated as a karaoke and its associated lyrics are displayed in the video screen. Additionally, you can have the MP3 and CDG contained together in a .ZIP file and it will see that as a karaoke as if the files were unzipped in that folder.
Hope this helps...
Hope this helps...
geposted Mon 28 Aug 06 @ 3:56 pm
So I gave this a try using my sony mini dv camera hooked up via firewire - the video screen was just a garbled mess. I tried messing with the settings, but no luck. Any ideas?
geposted Mon 28 Aug 06 @ 4:26 pm
I tried hooking it up via usb and it worked just fine!
geposted Mon 28 Aug 06 @ 4:44 pm
which cameras can you use? webcams don't have so good resolution..
geposted Mon 28 Aug 06 @ 5:28 pm
I always tough that sonyu dv cam only can go through firewire.How did you do that trought usb?
geposted Mon 28 Aug 06 @ 9:34 pm
I'm using a sony handycam DCR-HC20 - it's got ports for firewire and usb. Not a bad price either!
geposted Mon 28 Aug 06 @ 9:56 pm
@ frd1963: yea thanks ; thats exactly what i wanted to know;-)
geposted Wed 30 Aug 06 @ 1:51 am
So, you don't need a video capture card? Why?
geposted Wed 30 Aug 06 @ 3:08 am
[A Man and His Music]
ur not really captuting it ur playing it as a live feed...(i think this is right)
geposted Wed 30 Aug 06 @ 4:54 am
hi, everyone, I been trying connect a canon video cam via firewire, but all I see is lines, any help will be appreciated.
viva la musica
santosac46
viva la musica
santosac46
geposted Wed 30 Aug 06 @ 6:06 am
