I've just dowloaded V4 and it's impressive works guys!
However I may have missed some parameter but I have an issue with the TCV pitch .
I explain myself: I put the pitch on the turntable to let's say +6%, vdj detects it and the slider moves on the skin, but if i disable TCV control, the pitch comes back to +0%, whereas in 3.4 it stayed at +6%.
Any idea to fix it?
Thanks in advance
Any idea to fix it?
Thanks in advance
geposted Mon 28 Aug 06 @ 6:51 pm
Hmmm, maybe this is what happened to me? See my post: https://virtualdj.com/forums/54765/General_Discussion/TCV_-_Set_point_for_0__pitch_changes.html
Either way, it does seem like version 4.0 treats the pitch slider as a "relative" rather than "absolute" control... But it really shouldn't be that way -- it's counterintuitive, and it's not how a turntable would operate with regular vinyl...
Perhaps there should be an option to set the pitch slider to either "relative" or "absolute", the same way that the needle-dropping can be set?
geposted Mon 28 Aug 06 @ 7:41 pm
There is a post about this in the Bugs forum.
geposted Mon 28 Aug 06 @ 7:55 pm
Forwared to Dev Team
geposted Mon 28 Aug 06 @ 8:03 pm
Thanx djnorway! ;)
geposted Mon 28 Aug 06 @ 8:09 pm
I'm quite reassured if this behavior is not wanted :)
As a workaround I change the pitch in vdj and let my turntable's pitch at 0%, if this could help anybody.
Thanks for the quick answers and feel free to contact me for any precision/test...
geposted Mon 28 Aug 06 @ 9:05 pm
Quote :
for some reason i cant get bypass/passthru to workwith 4.0 anymore, i cant find the shortcut action to do it and my old shortcuts for it dont work anymore, under turntable the only thing i can see is timcode_active which turns the timecode control on and off not the bypass
geposted Tue 29 Aug 06 @ 12:10 am
Yes DJ Xeo, I'm having the same problem! What happened to the timecode bypass command ?
geposted Tue 29 Aug 06 @ 1:42 am
Is this what happen to you ? then i didnt understand well at the other post.
And yes this is a known problem, i myself reported it to dev staff during the beta testing.
Its the same problem when you use only one tcv/tccd to control both players.
Its already on the to-do list..
geposted Tue 29 Aug 06 @ 4:27 am
Yeah, I think what happened is I took off the TCV control for a minute while I was listening to some tracks just using the keyboard, but then when I activated the TCV again the pitch slider was at around +4%, so it treated that like 0%... Didn't realize that's what happened, but given this is a known bug, that's probably how it happened... Hasn't been a problem before or since, and glad to know it's getting fixed!
geposted Tue 29 Aug 06 @ 4:58 am
Ok now we speak...
workaround for now is everytime you disengage the timecode control for some reason, be sure
the pitch slider is 0%.
geposted Tue 29 Aug 06 @ 2:48 pm
any news on the bypass feature, anyone? its not the best quality but it saves me switching cables if i want to play some vinyl
geposted Wed 30 Aug 06 @ 12:32 am
