I keep hearing about visuals. What exactly are they? Can i assume they are those kaleidescopic effects you can get on a screen while playing an audio file. If so, where are they located in vdj3.4 and how can more be found and installed?
geposted Fri 01 Sep 06 @ 7:48 am
Yes that's what they are, In 3.4 there either with the effects or you can enable them to turn on when no video is playing automaticly , you can find them in the plugins section / video effects
heres a quick link http://www.virtualdj.com/addons/view.html?type=video%20effect
When you go to the page remember that they will say visual effects not the transaction or actual effect for the video
geposted Fri 01 Sep 06 @ 9:06 am
Any idea where to get the visual effects for 3.4? . I accidentally deleted mine after uninstalling 4.1. ( i still like 3.4 better, its more stable ) and the ones that are listed on the site now are for 4 only? please help.
geposted Thu 12 Oct 06 @ 11:04 pm
