iis there a way so as soon u load a new track on a deck that the effects disenguage??
geposted Sun 03 Sep 06 @ 1:19 am
The effects disengage now, when you load a track. Could you be more specific. You do know that we offer forums in different languages?
geposted Sun 03 Sep 06 @ 1:29 am
i was mixing on the left deck while crossfading to the right deck i looped out.moved all crossfader all the way to the right deck.cueded my next song(the left deck).now im crossfading back to left deck and then (the left deck)looped by itself.how can i fix this???
geposted Sun 03 Sep 06 @ 1:36 am
It looped the song that you just loaded? Is it possible that you hit the loop button by mistake?
geposted Sun 03 Sep 06 @ 1:42 am
nah it looped out by itself
geposted Sun 03 Sep 06 @ 1:46 am
Is this the first time this happened? Can you repeat it?
geposted Sun 03 Sep 06 @ 1:51 am
Maybe he has right clicked on the automix button and it is now in automixing mode.
geposted Sun 03 Sep 06 @ 2:59 pm
There is a setting in the registry (could also be editited with the registry editor of DJ Cel) that is named ClearEffectOnLoad. If this setting is enabled, then the effects of the deck will be switched off when you load a new track. If it is disabled then the effect will still be active after a new song is loaded.
Ewout
Ewout
geposted Sun 03 Sep 06 @ 5:57 pm
are u sure this dude is using 4.0? Cause disable effect on load is automatically on in 4.0 without having to go into registry.
geposted Sun 03 Sep 06 @ 6:13 pm
it only happens when i backspin the last track on the opposite deck
geposted Tue 05 Sep 06 @ 5:44 am
After using the backspin effect, you have to switch it off manually again in 3.4. In 4.0 the effects will be disabled automatically when you load a new song. Keep in mind that vdj4 only does that if the registry flag described above is set correctly.
Ewout
Ewout
geposted Wed 06 Sep 06 @ 9:53 pm
