I've just switched from 4.0 to 3.4 How do I remove the logo from the video output?
geposted Mon 04 Sep 06 @ 3:25 am
Go to your Video tab in the config settings, theres a check box for hide logo
geposted Mon 04 Sep 06 @ 6:25 am
Nah, that's only available in version 4 surely? Needs a registry tweak to get rid of the logo in 3.4...
geposted Mon 04 Sep 06 @ 7:24 am
it's the same in 3.4 ;)
geposted Mon 04 Sep 06 @ 7:29 am
No it's not (not in my 3.4 anyway)
geposted Mon 04 Sep 06 @ 2:54 pm
hkey local machine virtual dj set videonologo key to 1
geposted Mon 04 Sep 06 @ 3:07 pm
hey norway, you must have that special version of 3.4 with all the hidden features for important people!
hehe ;-)
hehe ;-)
geposted Mon 04 Sep 06 @ 6:26 pm
lol maybe ;)
Sorry for that, its been a while since I've used 3.4
Regedit it is then ;)
geposted Mon 04 Sep 06 @ 7:05 pm
Hey Cyder can you explain how to get the logo out step by step please?
geposted Tue 05 Sep 06 @ 12:43 am
Sure thing
1. click start
2. click run
3. type regedit hit enter
4. then navagate to h key/local machine/software/virtualdj
5. locate the videonologo key, then change the value from 0 to 1
be sure to change these settings when vdj is NOT running.
1. click start
2. click run
geposted Tue 05 Sep 06 @ 12:50 am
I thank you very much.
Maybe you can help me some more if you don't mind my video output is strobing what do I have to do?
I have a dell with 2 gig of memory & 128mb for the intel intergrated video card.I hope the info will help.
geposted Tue 05 Sep 06 @ 12:55 am
Sounds like the video card's the problem, they reckon you need 256MB to get it to work right, plus that 128MB you've got is probably shared memory. My laptop's a similar spec, it's fine for sound, but I've never managed to get video to work on it.
geposted Tue 05 Sep 06 @ 2:03 am
Is there anyway of upgrading the memory only for the video card?
geposted Tue 05 Sep 06 @ 2:40 am
Not that I'm aware of, I think you'll find the graphics on laptops are integral to the motherboard, so there's really not much you can do to upgrade it... :-(
geposted Tue 05 Sep 06 @ 4:03 am
