Why does VDJ add gaps between songs when I mix? It did not do so in V1.09. More specifically, when I record into multiple files it puts silence at then end of the first track, and silence at the beginning of the next track.
geposted Mon 05 Jul 04 @ 8:08 pm
That might happen if you're recording in mp3 format. Otherwise it should work normally with wave (didn't try it yet in 2.0, since I use an external program for recording).
geposted Tue 06 Jul 04 @ 7:57 am
Thank you.
geposted Tue 06 Jul 04 @ 6:15 pm
i had that problem too are u making cd's if so is it nero ur using u can try the remove silence option if not i would do what Erxon suggested record in wave i seem to get better cd's in wave anyway and it can make them faster
geposted Fri 16 Jul 04 @ 7:46 pm
