Hey, i broadcast on an internet radio site using VDJ and wimamp shoutcast 1.9. When i choose to connect to the site through vdj i enter all the info (ip, port number, password) i hit connect and then it says broadcast error, server answer"" just like that, what do i have to do?
geposted Tue 05 Sep 06 @ 6:03 pm
Hey, How Can I Brodcast On Virtual Dj Radio??
geposted Wed 06 Sep 06 @ 4:58 am
Hi,
I had troubles broadcasting too and I found a cowboy way to get around that. Just put your winamp plugin to soundcard output, turn shoutcast server on, connect the plugin to the server and it will broadcast all that comes out of your soundcard.
p.s. turn those system sounds off if its not already done.
Karlo.
Karlo.
geposted Fri 08 Sep 06 @ 1:58 pm
How exactly do i connect 'the plugin to the server"
I have the shoutcast server GUI up and running but could you explain this a little better for me?
I have been tryin to get this to work for hours.
thanks, jason
thanks, jason
geposted Thu 21 Sep 06 @ 5:52 pm
