I have been running vdj dac3 and cm200usb with great success. Is there a way to have the headphones work on chan a and b independently. Right now headphones are playing only what is coming out of speakers?
geposted Wed 13 Sep 06 @ 10:24 pm
By pressing the PFL buttons you are able to listen to a certain channel seperatly, and by pressing several PFL buttons you are able to hear the audio from the selected channels.
This is standard in almost every mixer on the market. Hope it helps!
geposted Thu 14 Sep 06 @ 9:40 am
Antileon, Thanks for the reply the problem is when I have the pfl button for usb a pressed I still hear whats coming out of usb B as well as usb a. I dont seem to be able to ever isolate the sound from each channel
geposted Thu 14 Sep 06 @ 10:06 pm
I have a cm200 usb mixer and i don't have that problem. Be sure that the cue fader is on cue position not on program position and the crossfader is assigned to 3 and 4 chanel and you have just one cue button pressed.
geposted Fri 15 Sep 06 @ 8:01 pm
Thanks, I will give this a try.
Thanks
Thanks
geposted Mon 18 Sep 06 @ 9:40 pm
did this work?
I am interested in buying the CM200 and am hesitant until I know for sure it will work with VDJ.
Thanks
Thanks
geposted Sat 14 Oct 06 @ 2:11 am
