Forum: Old versions
Topic: CPU Usage/Memory leak
Im having a problem with virtual dj 2.0. I first noticed it while attempting to load a sample into the sampler with a song playing in one deck. The music kept playing, but the load window would not come up. Cpu usage was around 70-80 percent. I ended the task. Tried again, had some success, then ran in to the same problem. Now whenever i start the program, the cpu usage sticks at about 60 percent, and the memory usage increases with every refresh. I let it go as high as 128 mb before terminating. This was without loading anything. Any Ideas?
geposted Thu 08 Jul 04 @ 11:43 pm
claxPRO InfinityMember since 2004
I had similar problems when deleting and renaming samples (with VDJ) while a deck was playing.
geposted Fri 09 Jul 04 @ 6:18 am
