Forum: Old versions
Topic: -HELP!-
I need help with scartching with the stick, every time I scartch, it sounds horrible. Any tips...?
-THANKS IN ADVANCE-
DJ MEGA MAN. ;)
geposted Fri 09 Jul 04 @ 10:30 am
Use the jog wheels rather than the stick for scratching - it sounds far better.
Just disable the 'use sticks for scratching' option in virtual dj/remote control
THANKS SPARKY!
Can you use the jog wheels in the un-licensed DJ Console version of Virtual DJ?
That function is available in VDJ2 (full version) only ;)
macourteau
okay, thank you. :P
do the jogwheels work as well for scratching as the mouse does in vdj on the virtual desks? that would be cool...
Lodewijk:
"do the jogwheels work as well for scratching as the mouse does in vdj on the virtual desks?"
NO! They work really better! (lol)
It IS really cool ;)
you're making it very hard for me NOT to buy VDJ 2. I'm trying to hold it off, and experiment with vdj 1.9 but vdj 2 sounds too cool, and a real step forward also for the hercules dj console... hmm... life is hard :)
there are many new features in the full version than in the herculies edition, even in 1.09 (Full Version). Version 2 is a giant leap in the software and is easy worth the money 100X over. (and it should pay its self off at your first gig)
Yes Dj Zero if you make a lot of a one gig, but not everyone has a lot of money from a one gig. If I had more money, I'll buy it twice, it is that good!
"has a lot of money" ???
Can you find a DJ Hardware (turntable, CD player, mixer or anything else) cheaper that VirtualDJ 2 ??
He's right. :p
