Sometimes when I press the paly button on my Hercules console the unit is not responding straight away.
I have to press it a second time, before it really starts the song on VDJ.
Very ennoying when you are mixing.
Anyone has a solution for this?
Maybe open it up and replace the buttons?
Thanks.
Thanks.
geposted Mon 18 Sep 06 @ 11:22 am
A lot of Hercules DJ console MK1 (First model) have this problem and one Italian guy have solved this with change of the Play & Cue switches
Automatic translation of google, the original guide is in Italian
http://translate.google.com/translate?u=http%3A%2F%2Fvoltron.osdealer.com%2Fmodhdjcmk1%2F&langpair=it%7Cen&hl=it&ie=UTF-8&oe=UTF-8&prev=%2Flanguage_tools
geposted Mon 18 Sep 06 @ 12:10 pm
Is this solved with the MK2, are the keys more responsive.
Better, are they working as they should, like a true hot start CD player?
geposted Wed 20 Sep 06 @ 12:12 am
yupp...
mk2 is super responsive, and can be compared to regular cd decks
geposted Wed 20 Sep 06 @ 12:39 am
mine was sticky too.after one year of light use its complitly gone.i use pc mouse to play which is really annoying.i try to open my consule but i dont know how to open inside consule.any idea?
geposted Wed 20 Sep 06 @ 8:53 pm
well, you have the mk1 model, that unfortunately turned out to be unresponsive after some use.
The mk2 model is completely different.
I've heard users fix the mk1 by adding come contact foil under the play and cue buttons, if you search this forum you might find the thread on how they did it...
geposted Wed 20 Sep 06 @ 9:22 pm
Well yesterday, I bhought a Hercules DJ console MP3, I have a separate soundcard after all, so I could save some money on this.
Well was I surprised that the keys indeed are super responsive.
They react instantly as I expect them to do, now let's see how it will be after a few months of DJ-ing.
Although I must say that I was a bit dissapointed that with the MP3 console no cover is supplied :-(, shame on you Hercules to save some bucks.
geposted Thu 21 Sep 06 @ 10:52 am
