I have recently purchased a Hercules controller that works fine, except it wasn't the one exactly as pictured. The one I wanted or need, the one with all the input and outputs(mine only has a USB connection). My friend told me that the one that i want has a lot of technical issues. Is this true, before I upgrade or not? I may sell the other one if not.
Thanks in advance.
Thanks in advance.
geposted Tue 19 Sep 06 @ 5:04 pm
what you want is the MK2 model, and I have no issues with mine... :)
The only thing that might be said bad about it (apart from size), is a bit slow asio drivers.
This only matters if you scratch damn fast (or slow) with timecode connected.
The mk2 model is FAR better than the other Hercules models (that are unresponsive etc)
MK2 has better jogs, and very good responsiveness on buttons
geposted Tue 19 Sep 06 @ 5:10 pm
I don't have the unit in front of me. Is the MK2 the one with or without the RCA inputs?
geposted Tue 19 Sep 06 @ 9:57 pm
mk2 has RCA inputs. definitely get the mk2
geposted Wed 20 Sep 06 @ 2:15 am
This is MK2.
geposted Wed 20 Sep 06 @ 4:19 am
