Hello,
I have spent about 2-3 hours trying to get the broadcast function to work properly.
I have configured my ports on my router to be open 8000-8001
I have even followed the steps people have provided in the forums for setting up a shoutcast server.
I can not get either the VDJ or Shoutcast serever to stream.
Is there a tuturial provided by the software mantufacturer for configuring this? It seems there would be, considering this seems to be a very common problem.
thanks, for any help, tips, links, replies.
-jason
-jason
geposted Thu 21 Sep 06 @ 4:47 pm
One more question what is the default Encoder file ?
is it this lame_enc.dll
C:\Program Files\VirtualDJ\lame_enc.dll
geposted Thu 21 Sep 06 @ 4:51 pm
buy it !
just a hint
aslo do u have a router?
as if this is the case ul have to port forward
just a hint
geposted Thu 21 Sep 06 @ 11:52 pm
A great function of this forum is the search. This problem has been faced so many times.
Lok at my old post here.
pier
pier
geposted Fri 22 Sep 06 @ 12:54 am
Guys...... can you tell me about the lame_enc.dll??? I have all set ip adress, password and when I press "Start Recording" it says "
**Broadcasting Error**
Encoder Error
I tried to adjust it myself but I didn't make it!! :(
Any useful advice would be apreciated!!!!!
Encoder Error
geposted Sun 21 Feb 10 @ 12:39 pm
OK Beatnik. I understand your having an issue. However, digging up a couple of very old posts is not the way to ask your question. I'm going to lock both of these threads you dug up and, ask you to start a fresh thread please. Thanks
geposted Sun 21 Feb 10 @ 1:19 pm
