Hi all
Please could someone assist me ? I have started scanning/ analysing all my music, the only problem is that my BPM is not showing 0 and no beat grid present. If anyone has any advice, please shout.
Thanks
Wallet
Thanks
Wallet
geposted Fri 22 Sep 06 @ 12:59 pm
Did you scan, or analyse your tracks?
geposted Fri 22 Sep 06 @ 5:28 pm
Did this happen to all of your songs ?
geposted Fri 22 Sep 06 @ 8:11 pm
I am having this same problem. It did scan the BPM until I hit a cretain amount of sounds with BPM's. If I delete a song that has a BPM associated with it I can scan another on in. Almost like the BPM database has a limit. I am trying to work with approximately 26000. I guess it is way too much for the BPM database. I looked in the registry to see if there was a limit. No setting that I saw.
geposted Sun 24 Sep 06 @ 6:14 pm
I am having difficulties getting tracks to scan in or analyse - even when I do, it does it at first - but, when I come out and go back in again, it says "The internal database is corrupted" and reverts back to original "as-new" configuration.
geposted Mon 25 Sep 06 @ 12:13 pm
Thanks a ton for the feedback, the problem seems to have sorted itself out.
I would just like to find out whether aanyone is experiencing a hissing sound through the console ?
I have the mkII but find it extremeley noisy through the system and speakers.
It doesn't sound as clear as it should, maybe you have some settings which I need to tweak.
Thanks again
geposted Tue 26 Sep 06 @ 9:51 am
try turning up the volume a bit and the hiss should stop
its the sound the card makes being amplified , it used to happen to me but i turned the vol to max so now its ok
Thanks again
Thanks again
geposted Tue 26 Sep 06 @ 10:44 am
