I have installed a VJD Home 2006. During installation no option for language was given. How can I run this in English?
Cheers
Cheers
geposted Tue 26 Sep 06 @ 11:27 pm
Run Regedit and in the registry key -- HKEY_CURRENT_USER\\Software\\VirtualDJ\\Language
change the value to 'English'
Also check your language.xml file in the Program Files\\VirtualDJ folder - if the language.xml contents are something other than English you will need the language.xml file. I just submitted it to the Language download selection. So, once it is reviewed hopefully they will post it.
Hope this helps.
cstoll
Hope this helps.
cstoll
geposted Wed 27 Sep 06 @ 4:56 am
Many thanks. Seems to have fixed itself????
geposted Wed 27 Sep 06 @ 8:01 pm
