Hey Guys!
Has anyone here had trouble with using the plug-in effects like the sound or video effects in VDJ v4?
I seem to be able to only play the flippin doubles plugin and even that does work out probally.
All the other effects that are orignially installed with the new update VDJ cant be ativated.
And even when I try to use them, VDJ crashes or displays the error message - "Error opening XML plugin file".
I would be greatly appreciated If someone can help me with this issue!
AS I have had to DJ at party without the plug-ins :(
geposted Thu 28 Sep 06 @ 5:11 am
Did you try downloading the newest plugins from the page? 3.4 plugins don't work with version 4.
geposted Thu 28 Sep 06 @ 6:11 pm
How do you know which plugins to download???
Wolfman
Wolfman
geposted Fri 29 Sep 06 @ 7:37 am
https://virtualdj.com/addons/skins.html
https://virtualdj.com/addons/effects.html
https://virtualdj.com/addons/videoeffects.html
https://virtualdj.com/addons/tools.html
if under the plug-in description you read "Compatible with Virtual DJ 4.x and Numark Cue" this is ready for VDJ 4.x , try it :)
geposted Fri 29 Sep 06 @ 11:24 am
Some plugins are still under development for version 4, meanwhile you can download those that cioce gave you.
geposted Fri 29 Sep 06 @ 6:02 pm
I have the same problem with the effects. I downloaded the one that says for vdj 4 and they still don't work.
geposted Sat 30 Sep 06 @ 5:29 am
I tried downloading the new plug-ins and I still have the same problem of it not working! I have also reinstalled VDJ 4 about 4 times!:( Any other ideas???
geposted Mon 02 Oct 06 @ 2:50 am
exactly what plugins are they
some require the latest version of DX9c (august 2006)
geposted Mon 02 Oct 06 @ 3:01 am
Pretty much all the plug-ins - video and sound effects and I have installed the latest Direct X drivers and still nothing works!
geposted Mon 02 Oct 06 @ 3:08 am
are they showing up in VDj?
geposted Mon 02 Oct 06 @ 3:20 am
They are all showing up, but I just cant activate them! Otherwise when I try it will show an error as described above or VDJ will crash
geposted Mon 02 Oct 06 @ 3:28 am
You can post this Topic in the plugins forum I'm sure a Plugin Developer will be of more help.
Sounds like somethings missing they should know what exactly it is
why not delete all the plugins from the VDJ folder and try reinstalling them then, or even delete the whole VDJ folder and registry keys after uninstalling, so that you can do a clean install
geposted Mon 02 Oct 06 @ 3:48 am
Thanks Mate for all the advice! Your a real help!
I'll take the problem to the plug-in developers and see what they come up with! If I find out the soultion, I'll post it here for anyone else who has the same problem.In addition I'll try reinstalling and this time also deleting the registry files!
Cheers and Thanxs to everyone who posted on this topic!
geposted Mon 02 Oct 06 @ 3:57 am
Good Luck , Hopefully it will be something simple
geposted Mon 02 Oct 06 @ 3:59 am
