I just redownloaded Virtual DJ 3.4 after having cueing problems (crackly noise that others are talking about) with version 4, and now the 3.4 I got seems to have bugs. I have tried several times to adjust the reactivity and it perpetually stays at "slow" mode..........additionally the program is skipping like crazy - all this after a RAM upgrade to 768 RAM and a lot of the suggested performance tuning. Any ideas?
I am becoming very discouraged by VDJ but trying to stay positive here!
geposted Fri 29 Sep 06 @ 3:17 pm
ok , to solve crackles turn ur volume up to full on the pc
ur simply amplifiying the sound of nothing ness
check ur cables are insulated
, change the proformance slider towards
reactivy not quality
press auto configure latency
defrag ur harddrive until no fragments remain
run only vdj when mixng
possibly get more ram
thats still quite small when you thing of it
and all should be well hope that helps!
geposted Fri 29 Sep 06 @ 5:34 pm
I did all of the things above already......I do use this computer for internet surfing but I always delete temp files, clear event viewer, delete unused software etc etc and I have 756 of RAM...
I may need a new computer.......this one has been giving me problems from day one to be frank
1.9 GHz, 756 RAM though you'd think it would do ok!!!!!
geposted Fri 29 Sep 06 @ 8:08 pm
Make sure that your soundcard and DirectX drivers are both up to date
geposted Fri 29 Sep 06 @ 8:47 pm
they are....I may run VDJ on two laptops.....will this use less resources? it would make me more comfortable to run two into a mixer...that way i got a backup
geposted Fri 29 Sep 06 @ 10:18 pm
