To many souncards...
ok guys, i have VDJ 4.0 with TCV and a pair of Technics 1200, and i just built a new pc and purchased the ECLER NUO4, the thing is i still don't have a audio card.
I also have SERATO but i got VDJ because i want to do videomixing, and what i want to now is...
if I get a U46DJ will it be as stable as the SERATO Interface?
or should i just go ahead and pay a little more for the HDSP RPM?
geposted Sat 30 Sep 06 @ 10:08 am
why not just use the serato sound card?
VDJ 4 supports the Serato Sound Card
geposted Mon 02 Oct 06 @ 1:44 am
I didi´t know it would work with VDJ...
geposted Mon 02 Oct 06 @ 2:13 am
i think the HDSP RPM is the serrato interface. according to what i heard they are the manurfacturer that produced the SL1s
geposted Mon 02 Oct 06 @ 2:14 am
With you SL-1 Card plugged in turn VDj on and scroll through the soundcards you should be able to see it.
BTW this is only in version 4
geposted Mon 02 Oct 06 @ 3:04 am
Nope, that would be the DigiScratch interface. While the serato interface is very good (better then most others IMO). The RME unit is quite a bit better still..
geposted Tue 03 Oct 06 @ 4:33 pm
you're right, thats what i was thinking of. but who makes the sl1s and the digi hardware in the rane 57sl? thought it was someone like that,,,,,,,,,,,,,,,,,,, for sure it is a good interface, with some good free software thrown in with it!
digi scratch never realy took off tho, i wonder why
geposted Fri 06 Oct 06 @ 1:02 am
