I cant get VDJ to work properly with the soundcard. I cannot cue with the headphones, even when I set it to ASIO driver mode. What should I do?
geposted Sat 30 Sep 06 @ 8:29 pm
why are you using the asio drivers? try it in 4.1 mode
geposted Sat 30 Sep 06 @ 9:15 pm
I only have 2 speakers? :S
geposted Sat 30 Sep 06 @ 11:43 pm
Both my speakers and my headphones are still in master...
geposted Sat 30 Sep 06 @ 11:46 pm
if the card doesnt have 4.1 or above you only could do it with a splitter
if it does you should enable 4 channels with your soundcards software prior to using the 4.1 option in Vdj
geposted Sun 01 Oct 06 @ 12:02 am
http://www.m-audio.com/products/en_us/AudiophileUSB-focus.html
Well.. I just bought it yesterday, so I dont really know how?
geposted Sun 01 Oct 06 @ 12:14 am
I'm actually at work and don't have 4.0 in front of me, so hopefully someone who does can give a quick hand
but that card does have more than 2 out, so it should be possible
geposted Sun 01 Oct 06 @ 2:51 am
Sound setup:
If you using external mixer:
Outputs:External Mixer
Sound Card(s):4.1
Front output is left deck, Rear output is right deck.
If you don't use mixer than:
Outputs:Headphones
Sound Card(s):4.1
Front output is Master out, Rear out is your headphones.
This card has 2 stereo outputs and 2 inputs so you can use TCV's also.
Remember to set your sound card in 5.1 mode in drivers or in windows.
Sound Card(s):4.1
Outputs:Headphones
Sound Card(s):4.1
geposted Sun 01 Oct 06 @ 6:08 am
Hmm... Well, now there's only coming sound out of one of the speakers, and there's no sound in my headphones? When i press the tab button (changing the deck), the speaker mutes...
geposted Sun 01 Oct 06 @ 11:42 am
Is there any special settings in the audiophile usb control panel software, that needs to be turned on? I think the software is to basic...
geposted Sun 01 Oct 06 @ 11:44 am
No solution to this problem. I think it has something to do with the soundcard, it is totally new, but it doesn't work very well.
I have the same problem in Traktor. Anyone who had the same type of problem with this soundcard? And what do you mean by 2 outputs? I can only see a Right and Left Output, isn't that the same output but just in stereo?
geposted Tue 03 Oct 06 @ 2:05 pm
